Is there a way to add a sketch layout when importing a Solidworks Pack and Go Zip file assembly?
Paul_T
Member Posts: 2 PRO
NeilCooke
Moderator, Onshape Employees Posts: 5,991
Hi Paul, Onshape will only import solid and surface bodies. Even if it did import sketches they would not be parametric since they were designed in SolidWorks. If you want that kind of functionality you should remodel your assembly in Onshape.Senior Director, Technical Services, EMEA5 -
Paul_T
Member Posts: 2 PRO
Thanks for the answer, I thought that would be the case but thought I would ask before redoing it.0
