Importing issues and issues with imported parts
ihor_gernagaihor_gernaga Member Posts: 24 PRO
edited July 2017 in Community Support
I've been unable to successfully import iges and step files. After importing I have no preview in part studio and no parts tree. Am I missing a setting or is it the file? Solidworks and Parasolid have imported.
My next question is, is there a way to add filets and chamfers to imported parts?
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87 image
    Please could you open a support ticket with an example file that is not working?
    Once you have imported geometry you can additional features including fillets and chamfers.
    Andy Morris / Head of Product Design / Onshape, Inc.
  • ihor_gernagaihor_gernaga Member Posts: 24 PRO
    Unfortunately, the part I am working on is proprietary and currently in development. I cannot share it at this point.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    STEP should be fine but please do not use IGES under any circumstances. It used to called I-GUESS for a reason!
    Can you not use SolidWorks or Parasolid?
    Please be aware that if you are using the free Public plan you should not be uploading proprietary data.
