how to move the sketch plain
gabe_goodegabe_goode Member Posts: 2
is there a way to move the sketch plain, so it exceeds pass the surface you have selected.
thank you.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    Hi Gabe,
     If I understand your question correctly, it looks like you want to create a  sketch plane which is offset from a surface. If this is the case you'll need to first create an offset plane and then create a sketch with the offset plane as the sketch plane. Here is a link to the help documentation on creating an offset plane : https://cad.onshape.com/help/#cplane.htm?Highlight=reference plane
    Paul
    I may be wrong but I read that as meaning to resize the blue box that indicares the sketch.  The sketch extends to infinity but it looks like OS uses some logic as to how big the box is.  Planes have drag handles in the corners but I don't believe sketches do.
