Window Layout options
jrs_spedley
Member Posts: 71 ✭✭
Is there anyway of using different window layouts?
I've just invested in an ultra-wide monitor and it is great, however it would be much better if I could move all the menus, project tree and search box etc to one side giving me the full width and height of a normal monitor for editing.
Is this possible, doesn't sound like a difficult thing to implement?
instead of this ....
The screen shots were in F11 mode which also removes the window's scroll bars, title bar, browser menu and browser tabs. This is better (if I didn't keep pressing escape to go back to "select" mode which keeps exiting F11 mode).
I can't imagine a different screen would be feasable with browser based editing, although a seperate popup tool window could work.
My goal would be to increase working area and improve flexibilty depending on working needs (e.g. many featurrescript options or expanding all drop down icons or removing icons for keyboard shortcuts) but like I say, if it is not trivial then it isn't worth it.
I only asked because I wasn't sure if it has already been implemented and I just couldn't find the option. Perhaps I put this in the wrong forum.
EDIT: Shift + ? gives a list of shortcuts, very handy (although annoyed there isn't an alternative to Esc - that takes me out of (F11) full screen grrrr)
