Insert DWG of DXF files in to assemblies?
david_gomez008
Member Posts: 6 ✭
Hello,
Is it possible to import imported DWG or DXF files in to an assembly to use them as reference for a design intent?
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
First, you would have to import it into a part studio, then insert into the assembly from the insert dialogue. Once inserted mate to correct position or if already positioned fix so it doesn't move.
6
Now my problem is that the DXFs are too rich or complete to be used inside sketches...
Thank you
Thanks
