How do you find the center of gravity?
kai_etringer
Member Posts: 10 ✭
and before you say the scales in an assembly, that shows the center of mass.
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,436What's the difference?Senior Director, Technical Services, EMEAI5
Optionsbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PROIn CAD space you would generally assume these to be the same, which they are if gravity is constant across the rigid body. If the object was large enough and rigid enough to have varying gravity, center of gravity would differ to center of mass.1
quoting my favorite answer: Center of gravity is the point in a body around which the resultant torque due to gravity forces vanish.
That means that for any rigid body, the two points are the same, because you can model rigid bodies in free fall as if gravity acted only on the center of mass, and forces on the center of mass make no torque.
Sorry if I explained it badly, I am not good at it. I often go to science (even though I'm not even close to an expert, not having graduated highschool yet)
