how do i extrude remove the shape of a spanner to make eva trays ???
sean_managh
Member Posts: 7 ✭
https://cad.onshape.com/help/#booleanparts.htm?Highlight=boolean
Only way I can think of to get that geometry is to start a sketch, then project edges, then extrude.
A quick way to get a hard edge would be to use the split command and cut each tool in half. Then you can create a sketch and use offset to get the outline (or half outline if you want to revolve for screwdrivers. )
