conditional colors based on dimensions
I'm designing a tab-and-slot assembly to be laser-cut out of several different thicknesses of sheet material.
During the design phase I need to be able to change the thicknesses on the fly, so I've set up variables for the thickness dimensions.
Wouldn't it be awesome if the parts could have a color applied procedurally, based on their thickness? Then I could see at a glance which parts were made from which material.
Cheers, Owen S.
