conditional colors based on dimensions
luke_jaeger100luke_jaeger100 Member Posts: 34 EDU
I'm designing a tab-and-slot assembly to be laser-cut out of several different thicknesses of sheet material.
During the design phase I need to be able to change the thicknesses on the fly, so I've set up variables for the thickness dimensions.
Wouldn't it be awesome if the parts could have a color applied procedurally, based on their thickness? Then I could see at a glance which parts were made from which material.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @luke_jaeger100 although this is a neat idea, it is not a workflow that would be used my a vast majority of users.  With that being said, it seems you want to add some automation based on a set of rules.  For example like a rule that would state when any sheetmetal part has a thickness of X change the part(s) to this RGB.  thoughts?
    I know this can't be done with FeatureScript, but is the Onshape API set up in such a way that it would be possible to write this type of utility to run automatically on rebuilds?  If so I might take a look when I get a chance.
    Arul Suresh
  • luke_jaeger100luke_jaeger100 Member Posts: 34 EDU
    That would be great, is it possible with current version?
    Forgive me butting in but I'd love to be able to set an RGB using featurescript.
    Cheers, Owen S.
    Cheers, Owen S.
    all is forgiven
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 558
    IThen I could see at a glance which parts were made from which material.
    @luke_jaeger100 Can you tell us why this is important to you?  What would you be doing with this information?
    I'm making tab-and-slot 3D assemblies from laser-cut sheet material. They might be built from multiple types or thicknesses of material (eg 1/4" luan, 1/8" cardboard, etc). When it's time to send it to the laser cutter, I need to gang up all the parts of each thickness on the appropriate sheet(s).  I suppose the very best thing would be some kind of workflow to do this automatically, but conditional colors would at least make it easier to separate them by hand.
  • hans_van_de_burgthans_van_de_burgt Member Posts: 12 EDU
    Well I have the same issue. Now I exported my documents in DXF, and change the color of the lines in Autocad. I would be better if this could be possible in Onshape.
    @luke_jaeger100 Are your purposes here solely for layout of cutting all the parts with your laser cutter, material estimation needs, or both?
    I was thinking ease of layout, but material estimation would be nice.
