Insert DWG of DXF files in to assemblies?
david_gomez008david_gomez008 Member Posts: 6
Hello,
Is it possible to import imported DWG or DXF files in to an assembly to use them as reference for a design intent?
  • david_gomez008david_gomez008 Member Posts: 6
    Thanks I found out after posting this question.
    Now my problem is that the DXFs are too rich or complete to be used inside sketches...
    Thank you
    Yes, I have had that problem too. Maybe we need an improvement request for better handling of large dxf's  in the sketcher if that is possible.
    I've submitted one but if you submit another one it will increase the chances of getting things done faster.
    Thanks
