How do I extend the perpendicular edge of an extrude to an adjacent curved part.
For this project:
https://cad.onshape.com/documents/82d64b594c9cf2851bf76e27/w/8624f8dabaae1c9cd362005d/e/64b71d5b06b1f4be8ae51bd1
I have an arm sketched on one plane. The arm is extruded to a certain height. The top of the arm is also filleted, but that shouldn't really matter.
At the end of the arm there is a revolved sphere. The vertical face of the extrude does not meet the surface of the sphere due to the curve of the sphere sloping away from the arm. I want to have the end of the arm extend into or to the sphere to make a solid shape. I don't care if it goes into the sphere or just up to the surface. So far, I have not figured out how to connect that gap.
You've shared the the document via a view only link so I'm afraid we can's show you the solutions.
I'd imagine the easiest way would be to use the "Replace Face" tool a bit like this:-
https://cad.onshape.com/documents/bedfcdf89a6e9e2fe39cb0a6/w/1cc2bd45a9a57752957e1f25/e/c1919b490320aa266c3bc01e
Let us know if you get it to work.
Cheers,
