What type of referencing system (Part number) do you use?
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
I just want to know the different referencing systems that you use with Onshape.
Usually for the definition of reference codes (Part numbers) a combination of the following parameters is used:
- Group, IdGroup or Category of the component
- SubGroup, IdSubGroup or SubCategory of the component
- Material or IdMaterial
- Time reference: Year, month, day, etc.
- Finish, IdFinish, Treatment, IdTreatment
- Manufacturing process, IdManufacturingProcess
- Color, IdColor
- Version, release, Idversion
- Project, IdProject
- Customer, IdCustomer
- Special identifiers:Sheet metal part, weldment profile, etc.
- A correlative number or code
31.2.20170810-0121
IdGroup.IdSubGroup.TodayTimeReference-CorrelativeNumber.
Please, tell me yours ;-)
Un saludo,
ProjectCode-TopLevelAssemblyNumber.FirstLevelSubassemblyNumber.SecondLevelSubassemblyNumber... .PartNumber
for example MRK120-01.05.012 means that the part is developed during project MRK120 and is firstly used in second level subassembly MRK120-01.05.000, which included into first level subassembly MRK120-01.00.000
MRK121-01.00.000
MRK121-01.01.000
MRK121-01.01.001
MRK120-01.05.012
MRK121-01.01.002
MRK121-01.02.000
MRK121-01.02.001
MRK121-01.02.002
MRK120-01.05.000
MRK121-01.03.000
MRK121-01.03.001
MRK121-01.03.002
And... What about another level of assemblies? Do you allways use 2 levels, no more and no less?
An the number in the rest of the code, is it a correlative number?
P stands for part (made in-house) so that codes doesn't get mixed up with bought accessories/components codes [Axxxx] or Col codes which begin with C or product code which is only numbers. Four digits are just running number to create identification for database, I'm not sure what means correlative..
So you could describe the letter as Category or Type ID.
Thats 0001, 0002, 0003...
