How do I continue the extrude of a smaller tube into a larger tube?
Hi guys,
I have a tube which I am trying to extrude in a concave fashion into a larger diameter tube but I can't figure out how to do it. I've tried loft but it complains about the selection having an inner selection. I've attached an image below.
Many thanks in advance for any help!
My document is here: https://cad.onshape.com/documents/103df7df35e7f8b79d212ded/w/6b205c965461e2886eab2c08/e/019bab8de258b3667687b65e
daniel_splawski Member Posts: 66 ✭✭
I drew two lines on each sketch to break the ring into to pieces and then made two separate lofts for each half. Perhaps it's a bit greasy, but it got the job done.
Perhaps a better strategy would be to draw the cross section of the part from the front plane and use a revolve to make the part
https://cad.onshape.com/documents/304888033b5f092d2259f0ae/w/839ecc2e9e26619b83473c43/e/c5b9ede1d434e8f227a7fc9f1 -
john_mcclary Member, Developers Posts: 3,959 PRO
+1 to revolve
If you had the fore-sight to know this taper was required at the beginning. It would most likely be a good candidate to have the entire profile of the tube and flange revolved from the same sketch.
But there is nothing wrong with adding this on later as a design change, especially if you already have references to your tube body.1 -
emagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
@gyrex With the sketchs you have created, You can:- create a loft with the inner circles
- create a shell (and press the opposite direction button)
- You can create a bolean feature if you want to create a single part
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6
https://cad.onshape.com/documents/de41813d4a9fc93ab7da9ddf/w/501862f0c49bfdd126c0c8a6/e/560b9b7d60980fea99907f96Eduardo Magdalena C2i Change 2 improve ☑ ¿Por qué no organizamos una reunión online?
Even something as simple as this, you got a few different answers to the same problem. All of them are correct. It's more important to understand how hard it would be to edit them after you have other parts attached either in a part studio or in an assembly.
Has a lot of pro tips
