How do I make a solid spiral on a cone with smooth transitions on top and bottom?
Hello!
I have made a solid cone with a helix on the surface and swept a triangle sketch along the helix to make the spiral, and also a solid 6mm cylinder in the middle of the cone, like a shaft. I would like to extend the solid spiral into the shaft with a smooth transition. And the spiral should also end smoothly at the bottom. I have no idea how to do this... any suggestions?
https://cad.onshape.com/documents/e1fad23b60bb6f8d749bb993/w/a4cd9352eff70880616cb539/e/4e4bb6adaaaec85340a7c595
Sorry about my bad english
Best regards
Kjell
Best regards
Kjell
daniel_splawski Member Posts: 66 ✭✭
Depends exactly what you mean by "smooth transition". For the bottom transition, if you just extrude the bottom of the object up and choose "intersect" it will chop off all the extra spiral stuff. As far as continuing the spiral on the shaft, you'll just have to create a second helix on the surface of the shaft and monkey with the settings until the transition looks decent.
What exactly are you trying to model here?1 -
mahir Member, Developers Posts: 1,317 ✭✭✭✭✭
The general procedure for creating a spiral of any shape is to create a swept spiral surface using a simple line as a profile and a helix for the path. That surface can then be split using a second surface that has the desired overall shape - in your case, a cone. The edge of the resultant split surface is a helix laying on a cone. To generate a lead-in/out, just modify the cone surface to have the desired lead-in/out.
This isn't exactly what you're trying to do, but it might be useful.1 -
MichaelPascoe Member Posts: 2,591 PRO
This is an old discussion, but in case you need to make a solid body spiral again, I made a feature that will help! Spiral
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴5
Here is the part now
https://cad.onshape.com/documents/264200ec474192e326599120/w/b2d5e12920e5c4d03f3c88a9/e/de4908b5648295d1c4269e34
Thanks! That works great. I think I can fix the transition at the bottom someway.
