Making micro-coil
yuval_taff
Member Posts: 17 PRO
hello,
i'm trying to make a micro coil (OD -0.35mm; wire thickness -0.075mm; length -300 mm; no pitch), but there's a limit of making that kind of coil (the limit is 1000 reps which give me length of 75mm). i can make few coils and add them in my assembly, but maybe anyone got a better suggestion to make this kind of coil?
thank you
thank you
NeilCooke
Moderator, Onshape Employees Posts: 6,004
Make a short coil then use linear pattern.Senior Director, Technical Services, EMEA5
