Making a drawing from assembly
in Drawings
If you want to fix it yourself (and if the complexity is the problem) then some of your remedial steps may include (and these are the same for all cad systems);
- Removing unnecessary detail (knurling, text, threads)
- Simplifying complex geometry (plates with patterns of many holes)
- Multiple unsewn surfaces should be removed or sewn together (each surface is treated as a part)
- Any imported geometry with errors should be fixed, removed or suppressed.
I recently did this for a Professional customer and with only minor changes took an assembly that couldn't make a single view in 10 minutes to being able to make 4 views in 35 seconds. It's very doable.Good luck
I found that the problem is made because of my complex micro-coil (0.35mm OD; 300mm length; 0.075mm wire thickness; no pitch), because i'm not able to make a drawing for the coil by himself.
theres a better way to make that kind of coil?
can i share my coil document with you to see if you find a solution?
thank you
