Loosing Mates when inserting parts and sub-assemblies into and assembly
Member Posts: 3 ✭✭
I don't know what I'm doing wrong and need some help. The same problem occurs in multiple situations.
1) I import an air cylinder as a part studio (it consist of four individual parts). In the part studio I cannot move the individual parts relative to one another. When I insert the cylinder into an assembly the part studio comes apart and I can move all four parts of the part studio relative to one another.
2) I create an assembly model that consist of numerous part studios. In the assembly everything is mated and holds its position. When I insert the model into a second assembly (an assembly into a higher level assembly) the mates come loose and I need to re-create mates in the second assembly.
Is this the way ONSHAPE is supposed to work?
  • Member Posts: 3 ✭✭
    Thanks for the help. I just went thru the bootcamp and now recall the group mate thing. Thanks again. I have some things to try.
