Sheet Metal Flat Model Export
john_mcclary
Member, Developers Posts: 4,059 PRO
Is there a way we can add an option to not include bend tangents on flat sheet metal parts?
It is a major pain to program sheet metal in mastercam with all of these unnecessary intersections.
When selecting an outside edge for example, mastercam will automatically trace around the part until it comes across an intersection. When that happens the user needs to click the next edge to continue the path. Not a big deal for most people, but our programmers are a bunch of princesses that need you to hold their hands while petting their hair and singing them a Disney song just to get them to do the extra 10 clicks per part...
Take this part for example:
each bend has two tangent lines which means each corner has 2 intersections.
So what does that mean for the programmer:
5 clicks per intersection, each question mark is mastercam asking which direction to continue.
What they are used to from solidworks exports is this:
red showing the removal of the tangent lines. Now it is only one click.
This is so stupid, but they complained to the owner this morning. And now that may be the nail in the coffin for us switching to OnShape
1
The point is to reduce workload.
The tangents are not necessary on export. Can they be removed?
half-a-step shorter workaround than what @mlaflechecad has proposed: export dxf/dwg, import in sketch, extrude sketch https://cad.onshape.com/documents/c7ef644ed4de91bf0875d77a/w/a422fc4ce00d3d2d1296a415/e/cc2e3118965f88892a5aab49
1. You have to select a face of the flat pattern to use it.
2. It "finishes" the sheet metal model, so it must be the last feature. (UPDATE: that no longer happens, thanks to another suggestion from Lana)
https://cad.onshape.com/documents/d075777b23239493791a6871/v/8668ea90f8ca4d2ecc91fcaa/e/904c42aa0d85c24083eeed8f
@john_mcclary - looks like Ilya/Lana just made you Queen of the Princesses!
suggestions?
I would be satisfied with this workflow if its just one feature on the tree, let's get this working
Hey, this works!
Huge thanks everyone! Our programmers are happy again, so am I.
Shame on you Onshape
I feel compelled to come to Onshape's defense here.
(1) The current features in SM are OS's first round introduction. They introduce new stuff pretty much every 3 weeks and have done so since launch.
(2) A whole bunch of the staff came from solidworks, including a certain chap by the name of Jon Hirschtick who founded and was the CEO of solidworks.
(3) In the thread you've inserted your comment into not one, not two but three Onshape staff have jumped in to help the original poster with their issue, and came up with a solution the same day.
(4) There is a great improvement request system whereby we as users can tell OS what we want, and if voted upon (again by us) then they make it a priority.
I'm sure in a way all feedback is good, but please try not to offend the devs, many of whom we're on first name terms with! All suggestions of how to make stuff better is more than welcome.
Happy CADing,
Not only did they solve this same day. The whole thread was solved within couple hours! And this was something so trivial to most people. Yet they still answered the call for the 1 cnc programmer that complained to my boss. They have always been there with prompt decisive service since I have been modeling with onshape.
All i have ever gotten out of solidworks is a "Thank you for showing us this bug. Unfortunatly this may not be fixed until 2018." And all that was said in feburary, where they had plently of chances to put it in a servicepack but didn't. Still havent... and it's in linear sketch patterns. Something that has caused parts to be manufactured with holes that mis-aligned. not just a quality of life improvement like this.
But it is true, there are some short commings with Onshape sheetmetal. But give it time. Solidworks didn't get it right even after a few years. Onshape sheetmetal is only a few months old.
It would help greatly if you could enumerate functionality you need, examples of sheet metal models you are looking to build would help even more. We hope Onshape sheet metal functionality will match your needs in near future.
I apologise to the Onshape staff.
