Spur Gear with more than 250 teeth?
adamohern
Member, OS Professional Posts: 216 PRO
@NeilCooke
@NeilCooke3D
I need to generate gears with more than 250 teeth. Why is there a limit on the spur gear FS? Can I disable it somehow?
@NeilCooke3D
Also, it seems I put a teeth limit in there to stop people being "silly" without any scientific fact of how many people might need. What would you consider is a realistic upper bound if I still have one?
https://cad.onshape.com/documents/5742c8cde4b06c68b362d748/w/b493e0cb681bbf9497d9f4b3/e/c72760543a0d4412e72f6d38
(though I will probably make a V3 once you get back to me on tooth limits)
