Single Line Font
bryan_lagrange
Member, User Group Leader Posts: 991 ✭✭✭✭✭
in General
Onshape has a limited amount of fonts to use for modeling. It would be nice to have a Single Line Font. This is perfect for etching part numbers or other ID information on parts with a laser to obtain a minimal path run. The current fonts give an outline of the font which is close to double the path of a single line font. The result is not shown for a small run of parts but when you have a run of thousands of parts, that need identification etched on them, then you see a big drop in overall run time.
A single line font is also useful when programming a path for mills or engravers.
Thank you
Thank you
It has been discussed many times here.
https://forum.onshape.com/discussion/5711/stick-fonts-for-engraved-legends-on-panels
https://forum.onshape.com/discussion/comment/26306#Comment_26306
https://forum.onshape.com/discussion/6382/how-do-you-upload-fonts-into-onshape
