Please help me generate a loft
gyrex
Member Posts: 32 ✭✭
Hi everyone,
I'm attempting to loft the 2 faces (Face 1 & Face 2) in the part below but I can't seem to achieve it and was wondering if someone could help please?
Link to document here: https://cad.onshape.com/documents/103df7df35e7f8b79d212ded/w/6b205c965461e2886eab2c08/e/bcd5c45edd764c5271e32ede
Many thanks in advance!
owen_sparks
Member, Developers Posts: 2,660 PRO
Are they identical face profiles? If so would a revolve be easier?
OwS.
HWM-Water Ltd5 -
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
you could use a filled surface to cap the top off. see them added to this doc
https://cad.onshape.com/documents/fb11dab93784f9803a523950/w/2728b60dd0afc54f14b45ce4/e/9a27108379880d4eef3d2a40
5 -
owen_sparks
Working version...
https://cad.onshape.com/documents/309a9f5b50c4975dc1ea01da/w/d038780bc0df181bc739bad7/e/552190da98eb1c3a1b144da2
HWM-Water Ltd5
OwS.
Can I ask what the requirements are of a loft? It doesn't seem to generate on many occasions.
I had a play in the mean time.
(1) No nested profiles (so do a specific sketch for each face)
(2) I don't believe they can share an edge as you have in face 1 and face 2. I managed a loft just separating them a tad, with the intention of a delete face or little extrude to put the missing bit back in. Seems over complicated though but has the benefit of allowing guide curves.
My last offering.
Pair of composite curves, one for each edge.
New plane to put guide on
Sketch with guide spline
Loft surface
Rest as per @brucebartlett method to build solid.
Interesting game. Same tome tomorrow?
Bruce - you may respond with a Welsh stereotype if you wish!
@gyrex that was a nice little challenge. Hope it works out for you.
@brucebartlett glad I could help you guys out with a challenge!
I've never done CAD before but I really love this stuff. It's a shame I didn't have a career in it. Onshape is a tremendous tool and the developers should be proud of their wonderful creation!
BTW, is there any way to work offline with Onshape? I'll be caravanning around Oz for 12 months soon and would love to keep designing, but internet access in remote areas will be bad at best and non existent at worst. Tinkering with Onshape is both relaxing and educational and I'd love to be able do this on the road.
@brucebartlett Sorry guys, I created a fill per your helpful tip. Does this fill function just create a surface? I can't seem to add this section to my part after creating it. I can see a new surface has been created in the parts list. I feel like I'm missing a step but I can't figure out what it is...
Also no offline at all in OS, and No, I'm a Welsh/English hybrid, so the intended joke was I'd reply as Bruce and he can do my reply. Guess if I have to explain it then it was a feeble attempt at humor...
OwS
(1) You need to set each fill surface as an "add" to the previous one, not a "new"
(2) Only two of your surfaces touch, the flat base misses the flat back by a tiny bit if you really zoom in.
Because there's quite a few common lines between sketches and extrudes, it kept selecting the wrong line. Have you got a tip for a novice such that I can select the correct line easier in the future rather than having to zoom all the way in? Is there some easy way of quickly hiding the lines of extrudes/sketches to make that kind of job easier in the future?
Yeah, I like to hide everything that could be mistakenly selected for such operations.
Tips:-
(1) Keyboard shortcut "Y" hides whatever you're hovering over. (Either in the main viewing area or the parts list.)
(2) "Hide all parts", "Hide All Sketches" and their "hide all other parts/sketches" equivalents from the right click menu also really useful here.
(3) Even with stuff set to hide OS will "helpfully" infer geometry from stuff that is hidden, which can muddy the waters here. A trick Philip Thomas mentioned is to create a plane on a face, then the sketch on the plane (not on the face) to stop this happening.
Have fun.
I'll send you the IP address of my 3d printer, just send a beer file to it!
Seriously though I'm no expert, I've just been using OS for a while so have picked it up from using it, a few videos, forum q's and webinars. Taking a go at answering other peoples questions is also a sort of training so of benefit to me too.
Cheers, Owen S.
Cheers, to virtual beers
