Parts not displaying properly/clipped from sub-assembly to assembly
Hi - I'm having an issue where parts are displaying fine in a sub-assembly but when I add that sub-assembly to a top level assembly they are clipped/not displaying properly.
If I go back to the main Onshape menu and keep re-loading the document eventually the top level assembly will display properly. Given they display properly in the sub-assembly I don't think it's a problem with the actual models themselves. Note the individual parts (bucket elevators) are actually linked assemblies from another document.
There are no errors I can see.
The sub-assembly showing properly:
The top level:
Any thoughts?
The top level:
Any thoughts?
NeilCooke Moderator, Onshape Employees Posts: 5,837
Sounds like a job for support. If you can make a version, create a ticket and share with support they will branch off your design so you can continue working.Senior Director, Technical Services, EMEA5
The items that aren't displaying properly are imported STEP files and are solids.
