Parts not displaying properly/clipped from sub-assembly to assembly
daniel_cookdaniel_cook Member Posts: 48 PRO
edited September 2017 in Community Support
Hi - I'm having an issue where parts are displaying fine in a sub-assembly but when I add that sub-assembly to a top level assembly they are clipped/not displaying properly.
If I go back to the main Onshape menu and keep re-loading the document eventually the top level assembly will display properly. Given they display properly in the sub-assembly I don't think it's a problem with the actual models themselves. Note the individual parts (bucket elevators) are actually linked assemblies from another document.
There are no errors I can see.
The sub-assembly showing properly:
The top level:
Any thoughts?
    Can you share the doc or is it private? are these modelled or imported? Surfaces or solids? Thanks.
  • daniel_cookdaniel_cook Member Posts: 48 PRO
    The document is private but I can invite you to view (or do you need to edit?). I'm also actively working on it at the moment.
    The items that aren't displaying properly are imported STEP files and are solids.
    Thanks Neil - I've opened a support ticket. Thanks for your help.
