Hide connector widgets?
Hobsie
Member Posts: 6 ✭
I made the mistake of hiding everything in an assembly and then hitting show all and now I have widgets for all my mate connectors that won't go away even if I go to hide the mate connectors themselves.
Widgets like this did not show until I hit show all. Is there an option i'm missing to hide these in the assembly?
First image shows the type of widgets I'm talking about, and the second is zoomed out to let you see how cluttered it makes things look.
NeilCooke
Moderator, Onshape Employees Posts: 5,932
J to hide mates, K to hide mate connectors.Senior Director, Technical Services, EMEA6 -
NeilCooke
If you right click the symbols on screen you can hide them from the menu there. On iOS you must select the symbol, then two finger tap to bring up the menu - you can only hide "other" mates/connectors.mark_hobbs086 said:Is that shortcut available as a menu option? I seem to only be able to locate "Hide Mates".Also, is there a way to do the same in the iOS app?
Senior Director, Technical Services, EMEA1
