Solid Edge Etch import into Onshape
bryan_lagrange
Member, User Group Leader Posts: 997 ✭✭✭✭✭
in General
If you use the Etch command in Solid Edge and then export the file as a .x_t file, go to options and check off export solids, sheet, and wires. When you import the .x_t file into Onshape, the geometry that you created in the etch command on Solid Edge will show up in the Onshape document.
Pretty cool.
Just wanted to share that with the community
1
Is this a feature Onshape should have? Sounds like it a different Parasolid feature to the std solid, sheet and wire frame.
And yes I use the etch command for part numbers.
It would be a great feature for Onshape to have.....along with Single Line Font.
Twitter: @BryanLAGdesign
@philip_thomas it would be really really cool to get this into Onshape to save using a dwg edit to add after export
Tickets are linked to stories and we add up the number of Pro tickets against each story to help us decide which ones to work on in the next sprint
