Why can't shell remove all the sides of a box and just leave the top and bottom? Bug or feature?
brad_phelan
Member Posts: 91 ✭✭
is good but add the back right side to the list and it fails.
I want to shell my surfboard profile and remove the side walls to generate the top and bottom skins. But because of the above limitation I can't seperate the top and bottom. I could #featurescript it but it seems an extravagence.
brad_phelan
Member Posts: 91 ✭✭
This can be solved with a combination of move face and boolean against the original shape
I'll probably featurescript it up.
The above solution is
at
https://cad.onshape.com/documents/f10a4813ff92ed33c78811e0/w/c09220311df8c0606b87d4af/e/5f770e7e954ddd09414b36450
TVP, Onshape R&D
You can see the effect here. This is the side view. The bottom floor has been thickened up normal to the surface. The white area is the resulting solid. It can't be subtracted cleanly from the large blue solid.
Leaves the user puzzled as to what has gone wrong
at
The best way to share a Custom Feature is to write it in a public document (make sure to create a version when you're done) and copy/paste the link to that document. That way other users who may want to use your feature can just open your document and add the feature to their toolbar like so:
As I have shown in answers above. This does not work if the angle between faces is not 90degrees. Move face is the solution.
