Insert helix into assembly?
Hi folks.
I'm sure we used to be able to put curves into assemblies, but when I try insert my helix I can't even find it to add. Am I going senile or was this possible and now it isn't any more?
I tried converting the helix to a composite curve just in case it was the wrong type of curve but that didn't show up either.
Thanks Owen S.
Thanks Owen S.
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Owen - it doesnt look like this is currently supported.
Step 1 - submit enhancement request
Step 2- let us know why you need this (posting here is fine).
I do not know yet how big this project is so i cannot give you any feedback yet.Philip Thomas - Onshape5 -
i have already made an IR for this, it is useful for driving assemblies with complex kinematics. but on par with this some kind of point-on-curve constraint type requared, optionally - aligning to Fresnes basis.
https://forum.onshape.com/discussion/6659/ability-to-insert-curves-in-assembly
6
Intent was a "quick and dirty" way to represent a spring in an assembly for a jig. I'd not modeled anything fancy as wanted the end user to buy into the concept before getting in too deep on the design.
TBH I'd rather not raise an IR for this and instead have the "thicken curve into solid" idea implemented instead. That would have been better in this case.
Cheers 'n' all,
We defiantly need an IR for a :smacksforheadsmiley:
