Splitting sketch line at intersection of other lines
tom_augertom_auger Member Posts: 132 ✭✭
edited September 2017 in Community Support
I'm working my way through the excellent sprocket tutorial here: https://www.onshape.com/videos/lets-make-a-sprocket and have hit a snag I think. We have a number of co-incident lines and circles and I need to split them so I can only select certain segments for mirroring. The splits must occur at the points where the lines/circles intersect one another, so there's ambiguity about which shape you are actually splitting. I can never seem to split the shape I need to split - when I find the coincident point, it appears to add the split to the other coincident shape.
I would have thought that pre-selecting the shape you wanted to split might prevent the other shape from being affected, but this is not the case.
Is there a trick to choosing which of two intersecting shapes you can split?
  • jrs_spedleyjrs_spedley Member Posts: 71 ✭✭
    Try right clicking on it then using the 'Select Other' option on the menu.
  • tom_augertom_auger Member Posts: 132 ✭✭
    Thank you to you both for your helpful answers.
  • emmett_weeksemmett_weeks Onshape Employees Posts: 29 image
    edited October 2017
    The sketch split tool is sticky in the way that it selects curves, so if you walk your mouse down a curve, it will split that curve instead of other intersecting curves.
