Clean Common Parts with export to parasolid then import back again - Worth it?
edited September 2017 in Using Onshape
Hi folks.
Toying with the idea of exporting my "set in stone" revisions of library parts to parasolid then back into OS again to create clean and faster loading files.  Especially where I've not modeled them sensibly, say with a chain of derives or direct edit.
Cons:- Loss of history, but if edits are required the source partstudio still exists.
Any thoughts on whether it's worth it?
Cheers, Owen S.
    Thanks @brucebartlett seems to jive with the theory.
  • robert_morrisrobert_morris OS Professional, Developers Posts: 173 PRO
    What about just moving the finished parts into a separate document and then using a link from your assembly to that document?
    I thought I read in some other post that when you link to a versioned part in another document that Onshape caches the geometry of the part, which should be similar in speed to an imported dumb solid. Plus, if you just use a link, you retain the ability to edit the part features more easily.
    i think OS only consumes additional resourses to rebuild geometry when the features are edited, in all other cases there should be no much difference.
    Thanks chaps.
