Use Variables with Linear & Circular Pattern ?
Cache_River_MillCache_River_Mill Member Posts: 225 PRO
edited September 2017 in FeatureScript
Use Variables with Linear & Circular Pattern?
I need to use a variable to tell the sketch how many pieces to pattern.
Looks like the part pattern will allow this but not the sketch patterns.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Please search the public doc called Pretty Patterns to see how to do it.
    @cache_river_millworks You're correct that variables can be used within a part pattern, a face pattern, or a feature pattern, but not within a sketch pattern.
    See my response to this question another thread for a technical explanation why. This is a current limitation of of Onshape, so right we recommend you arrange things so you can use a part, face, or feature pattern instead.
  • Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    No problem, will do.
