Many, many thanks for your comprehensive pictorial explanation.
I now know that tags and labels enable user defined "filing cabinet" drawers into which I can store my CAD designs.
When I have time (flat out right now helping an injured colleague), I will experiment with some ideas.
If I can prove that a "Label" can store my Solidworks fastener library, and access the library from all documents within Onshape, what a revolution!!
I guess I would have to create a SW assembly and place all my fasteners without mates into the assembly. Then zip it up (pack and go) and import it into OS.
Most likely I have the concept wrong, and it won't work.
If you need to edit one of those in Onshape, just 'hide other parts' to keep things simple.
I don't know which is better pack&go or step ap 214 but I suppose they both will do the transition.
And if you think forward, having all your 'old' fasteners in single part studio there is plenty of space creating/importing new stuff into same document without getting too crowded with tabs. So you could just name that doc fasteners and give it labels like fasteners, common parts, sw import, whatEverLabelYouMightThinkWhenLookingForTheseParts etc.
Imagine clicking "derive" then adding a bunch of tags such as "Created By Me", "Sensor" "Stainless Steel", "M20" and being presented with any part you've ever designed that matches the criteria. You wouldn't even need to remember what project it was for, what you called it or where you saved it.
The more I think about this the more outdated folders seem.
Think of documents like a loyal sheep dog or valet parked car. You don't really care where they are "right now", just as long as they come when you call them.
If you give this idea a chance, you will notice that you waste one click and valuable time every time you click to open document and wait for it to open the first tab for you - just to notice that you opened wrong document or click another tab in that document and wait again.
The whole folder thing becomes a lot more relevant when dealing with part files and assemblies of tradition CAD we use to rather than documents which are almost like the folders but much more powerful. I have about 250 odd documents in my list and never really found it a problem to sort through, i do try to group parts ie. fasteners or hydraulic rams into documents as well and can't see a real need for folders but if I was to flatten out all my parts, assy's, etc, there would be 1000's, not even counting versions, then micro version's. Therefore think the document/project container system works well where folders would not survive.
Things do not have to be organised that way reely, but it is more pleasant for my brain to see them that way.
For me, the need for a hierarchy type structure is a real need.
To have the benefit of the 2 world, I think that the only tool I would need is a page named "Folders" where I can créate the hierarchy I want with the labels names linked to the labels themselfs.
When I'm working on a project and then créate a document, I would love to be prompt for a Label (not just a name). When prompt for the label, I would be directed to that page of links to place that label in the structure or use an existing one. The document would have then to be automaticaly taged with that path
A month later, I start a new project, I create Documents, Labels and a Folder like structure for that project because I'm always prompt to assigne a Label.
If I want to use an existing document, I just tag it with a new label of that new project. And the document is automaticaly taged with that new path.
If Labels could be labeled, then we could (on that page named "Folders") clic on a Label in a project and see a list of Labels or sub labels and documents.
This is not my field, maby I am too simplistic, but I know that it would be great to find a solution so that we could better organise our work
Léonard de Vinci
In the Folder system when I save a document, with one clic, I place it somewhere in a structure that is logical for me. I do not have to think of all the tags I have to add to that document to créate it's own structure. Folders are more intuitive with a more global view. Labels have their advantages too, but they need to be complement to have the browsing quality and the global view of the Folder system.
Léonard de Vinci
