Centering a Revolute Mate on a Squarish Hole
I am an old dog trying to learn new tricks!
How can I center a Revolute Mate on a squarish hole?
This is a Vex robotics channel. Even the axle is square too but I haven't gotten to that yet.
Need to build 4 bar, 6 bar, scissor lifts. This is for middle school kids who are building robots, if it's too hard the kids are not going to use it. Originally they were trying to use Inventor which made me weep because it is so hard.
Vex has a library of Vex parts that could be imported into Onshape.
I can put mate connectors on the part before putting it in an Assembly but that is messy and dumb to put a mate connector in all of the holes in the part. Yes, it would be perfect if the holes were circular but this is what Vex uses.
Thanks for your expertise and comments.
kyokoo
kyokoo
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
Add a Mate Connector in the assembly. Select between from the drop down, then select a face and the top edge of the hole then also tick move to rotate around the x or y to get the mate connectors z in the direction of the hole.
6 -
owen_sparks Member, Developers Posts: 2,660 PRO
Personally I'd pattern the mates in the part studio so you have one ready to use in each square. You could then label them say Rows A to C, Numbers 1 to whatever and then should you need to reference how to put it together you could say mate to C3.
O.S.
HWM-Water Ltd5 -
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Philip Thomas - Onshape5
O.S.
I'll ask another question on the best way to align channels! Thank you for your expertise.
I'm working with the teacher of Percy Julian Middle School program, this is what middle school kids are doing now:
https://www.flickr.com/photos/7805503@N04/33372881000/in/album-72157682050635355
We are looking for a collaborative design program to allow the kids to mess around with design ideas.
