Exporting to SVG
josh_jannusch
Member Posts: 2 ✭
Is there a way to best export a drawing to a SVG file. It is easiest to use the CNC machine with this type of file and want to know the best way to do this. I am struggling on finding a file converter to do this.
Thanks
Thanks
https://convertio.co/dxf-svg/
You'd need to export your drawing as a DXF first, of course.
Export this as a PDF. The PDF can be used with Inkscape or Gravit.io designer or directly on the Glowforge.
但有個注意的地方Inkscape直接開啟時,縮放方式要選Manual Scale
還有字元編碼要選Latin 1,不要選UTF 8
這樣開檔案才能順利打開
最後另存新檔,存成SVG檔就可以了
(我試過其他不同的方法,或者網路轉檔dxf -> svg,都有尺寸變形的問題!)
I did the "Glowforge Colorific" Fusion 360 post (https://github.com/garethky/glowforge-colorific-fusion360-post). Maybe now that CAM is coming to OnShape we can do something similar in that cam system. Lets hope that the CAM system isn't a Pro only feature.
This works but I'd to be able to fasten mate my parts to I can use one pass of the laser to cut and reduce time & waste. I just tried doing so with a Dove tail box design (DaveTail_v3) but when I bring these into Tinkercad it doesn't understand the models get corrupted.
A SVG export direct from OnShape that respects models/shapes connected via mates would be a great addition to an already great program
https://glowforge.com/latest-improvements/new-premium-perks-and-a-new-proofgrade-setting
A little late to the discussion but I thought that I would add this for anyone who stumbles upon it looking for a direct way to export to SVG….
To export to SVG directly from Onshape, you have to first create a drawing. Place the sketches you want to include on the drawing and then export the drawing. SVG is one of the format options. I usually delete everything else on the page first (or start with a blank template) before adding the sketch to it. You probably also want to set the scale in properties for the drawing to 1:1 before you export.
