use variable in assembly
mohammad_hajimohammad_haji Member Posts: 8 ✭✭
Hi,
I've been trying to use variable in assembly, but I'm not successful.
Who knows how can use a variable from part in the assembly?
Thank you
  • eric_pestyeric_pesty Member Posts: 2,382 PRO
    edited May 2 Answer ✓
    Not if you uncheck the "Insert into all Parts Studios and Assemblies" checkbox. You can then manually choose exactly which variable(s) to import in any assembly.
    Sorry variables only extend to PartStudios today.
    To what end do you wish to use them?  There may be another approach.
    Cheers,
  • mohammad_hajimohammad_haji Member Posts: 8 ✭✭
    To use in unpaired or not direct related to or more parts in 2 different assemblies.
    For example, relation between a cylinder bore to a lever in assembly. one number using for a 2 different type of calculation. Force & length.
    Why ca not use a variable number like this:
    #X@Part1 ?
  • jim_sungjim_sung Member Posts: 3
    I'm modeling a dining table.  I have a parametric variable called "reveal" that is used by other parametric variables that in turn constrain various parts, so it is needed in the Part Studio.  However, I also need the parameter in Assembly ("offset" in "Fastened mate"), but as pointed out by @owen_sparks, parametric variables are not visible in Assembly.
    I look at configuration variables, but I don't think it is applicable to my use case.
  • Scott_MorrisScott_Morris Member Posts: 17 EDU
    I would like to set the offset distance of many components to a variable so i do not have to visit all the connections to update the distances as things change.
  • _anton_anton Member, Onshape Employees Posts: 493 image
    You can drive your design from the top with a Variable Studio - those variables can be used in Part Studios and Assemblies.
  • S1monS1mon Member Posts: 3,618 PRO
    Ons solution would be to have some sort of a skeleton sketch that you can assemble your parts to. Build the offset distances into the sketches.
    You can do this if you define your variable in a "variable studio"
  • daniel_melamethdaniel_melameth Member Posts: 10
    @eric_pesty The problem with using a Variable Studio is the variables are shared across all tabs in the document.
    Even though seven years have passed and so much has changed — new features, new updates, and all done by your successors — I really appreciate that you noticed my old question and took the time to reply. Thanks a lot!
