Fundamentals 4 - error on Offset value?
bruce_williamsbruce_williams Member, Developers Posts: 842 EDU
edited November 2017 in Product Feedback
@KatieHuffman  I needed to use 35 mm to get the it to 'look' right and the correct mass at end.
www.accuratepattern.com
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    Bruce,
    Step 22 of this exercise asks you to change the dimension on the midplane offset to 35mm, to simulate design changes, and their effect on the geometry. Step 21 asks you to make changes to the master sketch as well. These steps must be followed to get the correct answer. Thanks!
    ah!  the instructions...  :smile:   thanks @KatieHuffman
    Is this the best place to post these kinds of questions/issues?
    Yes, if all else fails, and only if all else fails, we will read* them.
    *And by read I mean skim through. :p
    Owen S
    @bruce_williams
    You can use the "ask a question" option in the Learning Center for these kinds of questions/issues.
    Thanks!
    @KatieHuffman I did not see anyway to share screen shot.  Am I missing?
    You cannot add a screenshot, but it shows the instructor where you are in the Learning Center when you ask.
