Click and Drag
I can't believe I have to ask this, but how do you move an object from one location to another?
I have a 3D object, and its in an awkward position on the grid. I want to move it to a more comfortable spot but the bloody thing won't cooperate.
Please don't tell me it's stuck there.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@tj_thorniley
If you use the "Translate by XYZ" option of the Transform feature, you'll get drag handles that allow you to free drag your object. This works for desktop and mobile.
Jake Rosenfeld - Modeling Team2
OwS
Your entity selection seems fine, the issue is probably with your selections of how to transform the object. What transformation type are you using? If you are using translate by line, you should pick one line or two points to translate along.
If you're a developer, feel free to contact me if you want some help making the interface more intuitive. That's what it needs more than anything.
Sure we could have a triad and drag in xyz, but what if that isn't the desired direction?
The current translate options already do so much more than that. The translate by mate connectors is fantastically useful and requires no math(s) at all for complex manipulations. Translate by points similarly so. If we really want to move by xyz that's there too.
Offered in the spirit of healthy debate,
Other than that, it's hard to understand the other options you mentioned without some sort of visual cues. Maybe you could throw up some screenshots, or short video clips.
So say we have your lens and now want to mount a pair of them onto a microscope body, in the 2 points highlighted here:-
Now we don't know exactly how much to move them by or to rotate them by. And anyway this distance might change if we modify the design. So instead I've created 2 mate connectors (think of them as local coordinate systems). One on the lens, one on the body.
We can now carry out a transform between mate connectors to put the lens into place:-
To highlight a different method we'll now fit the 2nd lens in a different manner. We already have the point on the sketch where we want the centre of the lens, so just transform between them. We don't want to move the first one so I've checked the copy box.
I've added this into the previous doc I created for you should you wish to follow along.
https://cad.onshape.com/documents/b6a887c3cdcfbf681b9c9373/w/f16831af92b9443420026b87/e/2b158c9b00f1666108d2bff7
BTW I believe the 6 Axis drag functionality you describe is already in the "assembly" mode rather than the part studio mode. There are also a bunch of snap together mate functions which are really cool.
Hope that helps,
@owen_sparks has a great explanation of both the precision placement in part studio and mentions you CAN do the click and drag in assembly. It looks like you are working in mobile app. If you have not, give the browser a go on computer. There you will find full function and a lot easier to figure the software out. Mobile is amazing but it is limited by the size of screen and no mouse.
@owen_sparks Nice pictorial. Much easier to understand. Thanks. Can this technique be used to move the 3D object (or 2D sketch) (lens, in this case) to some arbitrary location in empty space? Like, instead of putting it onto the platform, what I'm trying to do is more like.. Keeping it next to the platform but moving it an inch closer, or further away.
Actually the object is too far away from the center of the document, where the planes intersect.
We're sorry your frustrated, don't give up! We're here to help!
If you go on the desktop version and post a link to the document here we can help figure out what happened.
A couple ideas:
If your "Transform" feature is before the features you used to shape the lens, then when you go to edit the feature it will look how it did at that point in the history. Once you commit the new changes to transform, the subsequent features will be recalculated and your part will go back to looking how it did with those future features.
Additionally, every change you make to a document is stored in the document's history, nothing you do in a document is ever ever ever lost. When you mention history, do you mean the Feature List or the Document History?
https://www.onshape.com/cad-blog/tech-tip-how-to-easily-restore-a-document-in-onshape
Here it is: https://cad.onshape.com/documents/aa47d0c5025c5bb0152dbc24/w/d8721353c80538ea7a8136b8/e/9f9ebca7c47b434916ddeaa1
When you see the outer shell, you'll probably understand why my workflow consists of multiple stacked sketches, extrudes & chamfers, etc. Rather than drawing it all in one go.
Oh yeah, and I was talking about the Document History. I think. It looks like this.
The document has multiple part studios -- my guess is the problem is that that wasn't clear. One is a grey cylinder, while another is yellow and has more work -- here's a direct link: https://cad.onshape.com/documents/aa47d0c5025c5bb0152dbc24/w/d8721353c80538ea7a8136b8/m/d636ddf3bcf252c223ba45c7/e/601c29a3494567ce3585a162
You can see the tabs at the bottom of the screen labeled "Part Studio 1", "Part Studio 2" etc. and switch between them.
