how do I make a compound curve?
darrin_jonesdarrin_jones Member Posts: 15 ✭✭
Ok I'm not sure even what question to ask. what i have is a profile that I want to sweep ( i think) the profile into a 90 degree corner, but following a particular shape. I've tried everything I can think of and I figure there has to be a way to do it but I don't know if I'm going about it the right way.
see drawing I'm wanting to fill the gap to match the profile
https://cad.onshape.com/documents/bb04c165ff728185574f76a8/w/5438e09251e13b0e9b71a29d/e/bb428c23ad13a4be0df936cf
  • darrin_jonesdarrin_jones Member Posts: 15 ✭✭
    thanks Neil that's what I was after. and when you explain it like that, it makes sense. I was trying to make it too complicated...
    Nice challenge.  The inside is easy with a surface sweep.  I did not get the outside to work; tried guide curve at corner with Fill Surface and that was ugly...  Be interesting to see solutions!  This is an example of the kind of surfacing I need.
    www.accuratepattern.com
