Sketch Copy
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Could someone help please. I have created a sketch of a CSK woodscrew on the front plane which I have revolved. the sketch is complete and my part is created. As I would like to create screws of differing lengths I have tried to copy the sketch into another part studio. However when pasted The origins do not coincide , maybe I am missing something. Any advice would be appreciated.
Best Regards, Brian
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,420
    You need to use the sketch transform command to move the copied sketch to the correct place.
    Thank you Neil. Been trying for at least 2 hours. (all part of learning curve)
    @brian_pinder662
    You could also just "Duplicate" your part studio (by right clicking the tab at the bottom of the page), and then in the copy of the part studio, change the parameters you wish to change.
