Is there an auto-baloon feature in OpenBOM?
1
Hi @panagiotis_herodotou688
OpenBOM is passing data to Onshape drawing module, which is used by Onshape insert BOM command.
You can use Balloon Number property in OpenBOM to order BOM in the drawing.
https://medium.com/@openbom/how-to-keep-an-openbom-bom-sorted-in-onshape-drawing-33c9eb8be603
Coming release will allow you to rename properties in OpenBOM (including hardcoded Onshape property names) to show in Drawing BOM differently.
Check this preview - https://medium.com/@openbom/openbom-for-cad-drawings-b64182d9095f
Although we are not controlling "Insert BOM" command (it is done by Onshape), we can think about applying running number in Balloon Number property (1, 2, 3, ...). Would it be helpful? Is it what you are looking for?
Best, Oleg
Check out my blog about Engineering and Manufacturing Software - http://beyondplm.com
