How can I use an SVG drawing in a part studio or assembly?
arasaras Member Posts: 16 ✭✭
I have a 2D shape in SVG format and I uploaded the SVG file into my OnShape docment. It is now in a new tab and I can view it, but I can not figure out how to use that drawing in a part studio or assembly, to actually work on it. What am I missing?
    I'm sure DXF import is on their list. Are you using SVG directly or do you have a converter you normally use?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @Aras We plan to support DXF in for sketch creation. I have added you to the list.
