How can I use an SVG drawing in a part studio or assembly?
arasaras Member Posts: 14 ✭✭
I have a 2D shape in SVG format and I uploaded the SVG file into my OnShape docment. It is now in a new tab and I can view it, but I can not figure out how to use that drawing in a part studio or assembly, to actually work on it. What am I missing?
    traveler_hauptmantraveler_hauptman Member, OS Professional, Mentor, Developers Posts: 419 PRO
    I'm sure DXF import is on their list. Are you using SVG directly or do you have a converter you normally use?
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002
    @Aras We plan to support DXF in for sketch creation. I have added you to the list.
    jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers Posts: 657
    Currently you cannot use a SVG in Onshape.
    Jake Ramsley
    edited April 2015
      That's ok. What formats can I use to import existing drawing? I tried DXF and that did not work either.
    Can't. Yet....
    If you have a different solid modeler. SVG->DXF->Extrude the profile into a solid->STEP->Onshape
    The list of formats is here: https://cad.onshape.com/help/#export.htm
    How can I request this feature? I do plasma cutting and all our clients use DXF and sometimes SVG. It would be a hugely important feature to be able to import those right into onshape.
    Is there an existing ticket for this somewhere?
    I use Inkscape most often and it can save as DXF as well as SVG.
    jess_robinson995jess_robinson995 Member Posts: 17 ✭✭
    Since I came here looking for the same thing - here's an update: https://www.youtube.com/watch?v=XWLQ5EMPRZo - and it seems to work.. even though not listed on - https://cad.onshape.com/help/#translation.htm?TocPath=Importing & Exporting Files|_____1
    edited June 2017
    @jess_robinson995  Maybe this help article is the one you're looking for?
    https://cad.onshape.com/help/Content/insertdwgordxf.htm
    Sorry that you had to dig for the information you were looking for.
