Adding new materials
tj_thorniley
Member Posts: 65 ✭
How do we add new materials? One of the parts in my new design is a light polarizing film. Apparently, it's usually a thin sheet of polyvinyl alcohol plastic (PVA/PVOH), but it's not available in the drop-down menu.
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,377@tj_thorniley - https://forum.onshape.com/discussion/7841/improvements-to-onshape-december-4th-2017#latest
Senior Director, Technical Services, EMEAI5 -
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,6461.19 g/cm³ * 1/1000 kg/g * = .00119 kg/cm³
.00119 kg/cm³ * 100 cm/m * 100 cm/m * 100 cm/m = 1190 kg/m³
Jake Rosenfeld - Modeling Team1 -
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭I see here a unit translation challenge
1.19 g/cm³ (g->0.001 kg, cm->0.01 m) = 1.19 * 0.001 kg /(0.01 m)³ = 1.19 * 0.001 / (0.01)³ kg/m³ = 1190 kg/m³
3
We don't provide time tables for when features will be released, but we absolutely use the votes from customers to prioritize the work.
-John
https://forum.onshape.com/discussion/4010/user-defined-materials-or-adding-a-weight-for-a-part#latest
Currently, this is the second most voted IR. Please add your vote.
According to Wikipedia, the density of polyvinyl alcohol plastic is ~1.19 g/cm³.
Does that make it 1190 kg/m³?
Or .0119 kg/m³?
