2D engineering drawings & DXF file output/input
mike_nelson
Member Posts: 4 ✭
One thing that I need before I can really use this tool is to be able to produce professional 2D drawings. Most of the subcontractors require me to send PDF version of 2D drawings for their use on the shop floor. I also need to be able to produce accurate 2D DXF profiles that are used in Laser, Plasma and Water Jet cutting of a lot of the parts that I am having made. I have looked in vain for this functionality. Is it there now? coming soon? or further in the future.
If some samples of what I am currently producing would help I can provide - I have so far produced just over 1000 drawings of the Baldwin Locomotive we are building and a good number of the parts have been made directly from blanks cut using 2D DXF files.
A lot of the initial design is provided to me in 2D form (autocad lite) by a designer who has never used 3D and doesn't want to learn - at least I did manage to drag him away from his drawing board and pencil.
Mike
Mike
2
picture below all parts cut using water jet guided by DXF files
I will also down the track what Sheet metal.
Sheetmetal is also one of my core requirements but think it will be sometime before we see it in onshape (hope i am wrong). I have played with using the a second flat part in the part studio done by hand calc's, but have all most forgot how to do these, I have become so reliant on Solidworks. I never seen it but heard spaceclaim has good sheet metal, we've got tru-top's down in our laser office which supposedly has Spacecliam sheet metal incorporated might have to go down later and have a play.
I do similar parts to you from a "modelling perspective" (I would not know the first thing about a boiler) and am looking forward to more functionality eg. mirroring and patterning in an assembly, configurations in an assembly and ability to have multiple instances of a the same parts in a part studio to avoid an assembly altogether and weldment functionality. However as I work on Solidworks I keep coming across problem's that Onshape will solve. Just have to be patient.
Yes, SpaceClaim's sheet metal is brilliant. Awesome how it can convert imported models into sheet metal features.
Dries
Saplingstore.com
DWG is fine if that's better or easier to handle than DXF.
DWG & DXF are the same thing, DWG is the binary equivalent (compressed) of DXF. If one doesn't work, the other typically doesn't work. I really don't like either, but when I have to, I'll use DWG because it's a smaller file size.
Welcome onboard, what are you machining? Can you show an image?
I'd like to model something in 3D to see if it will work, but then I want to make it in a shop. How do I do that without being able to print out dimensioned drawings? At this point, I've decided to learn how to model in OnShape on the hopes that this feature will exist soon. There is a video out there showing this, labelled "coming soon." I'm hoping it's true. The video looks pretty awesome actually.
David...
