Solid extrusion unavailable?
David_LaPointDavid_LaPoint Member Posts: 10
What would cause this? If I select solid, it extrudes surfaces, if I select surface it extrudes the same surfaces. I can't get a solid extrusion here?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,412
    Is part3 hidden?
    No, it is shown i believe
    Please share a link to your doc
    Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 211
    edited January 2018
    This appears to be a parasolid error since it looks like you have only solid parts and they appear as surfaces, so faces are missing. Notice on your first picture the face is transparent on once side and opaque on the other.
    Rolling back before your broken sketches, fix them, and rolling to the end might fix it.
    Please file a support ticket so we can better handle this.
    Support & QA
