Extruding symmetrical elements results in asymmetry?
I have a gouge blade (90 degree with 15 degree rake angle) that I am trying to model, and asymmetry is popping up.
The two cut sides should be the same... but one is 90 degrees, and the other has the proper angle.
I have spent hours trying to understand why, and would like some help.
https://cad.onshape.com/documents/5eb8957c9916dd8a2cc31ea6/w/fecf0985abc589292f81dbf9/e/32c73b253da8ed7d3f84b844
...also, a link to how to post in this forum (images, links, etc.) would be helpful...
Thanks, Curtis
Thanks, Curtis
You'll want to remove the vertical/horizontal constraints of the sketch, then make the lines coincident with the edges so that they are what the projected edges would be. From here it should cut at the 15 degree angle.
To attach image: Choose the image icon (next to attach file) and paste in a copied image (it does not have to be URL).
You can add links to text like this - Extruding symmetrical elements results in asymmetry? By selecting the text, then the link icon, and paste in the URL. Here is picture of steps -
...although there is symmetry in the sketch and its plane in relation to the part, but there is a dotted line (sketches 4 and 5) that shows asymmetry. I have tried to make two separate parts, but was unable to get the profile as desired.
Where is the mistake?
Thanks for looking at this, I really need some help, it is beyond me at this point...
-Curtis
https://cad.onshape.com/documents/1f870af61556d44bac1bb194/w/7f8fb2db151dfb128c69a9f8/e/9a243b77fafa1077caaebdf4
