I need to add a fillet here for more support how can I do it?
DarK_AlximiK Member Posts: 11 ✭
It does work over that step you have there intersecting with the tube5
If the cylinder and the block are separate parts, you need to merge them before placing fillet.
https://cad.onshape.com/documents/22e1330fb42449e30e7653d4/w/70c36757a9ea6eceb270d0b2/e/5331a84812720ae7d33ea4f9
