Variables in Configuration
turan_aydinturan_aydin Member Posts: 16 ✭✭
Hello,
Is there any "trick" to assign Variables to the values in Configuration table or this is not implemented yet?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,390
    What are you trying to do?
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,176
    Configuring variable values should work -- configure them like you would any other feature (e.g., edit the variable, right click on the field where you would enter the variable value and click "Configure").
    @ilya_baran
    I think @turan_aydin wanted to use variable in configuration table as value.
    In that case, yes. Just put # before the variable name in a cell.
    jerome_goyetjerome_goyet Member Posts: 11
    Hello,
    About configuration variables, I'm currently facing the follwing issue :
    With reference to this document (part studio 1 _ version B2_janv2018) : https://cad.onshape.com/documents/9181221e67016abc6e611600/w/1177aed0fb69afc9f9fdb1bf/e/5d9c264a121f1f416843aa28
    in the linear pattern 2 feature, the instance account is set with the '#nbr_ventaux' variable; this variable is defined in the configuration variables.
    Graphically, this linear pattern works correctly when the variable is set to less than 5; then, when it is greater than 4, only 4 instances are displayed.
    I cannot figure out if it is an issue related to the variable or a video generation issue ?
    Would you have any hints about that kind of issue ?
    Many thanks
    @jerome_goyet the issue is with your transform feature. As more instances are added, the transform feature does not know about them. You can change the variable to the maximum value it will ever be and add the extra instances to your transform feature. This should have been modelled in meters from the start.
    Got it!! Many thanks for your prompt response!
    yes @3dcad, I want to set variables in configuration table , but @NeilCooke I'm not getting how to do it. Example , I have prism  L100 x H50 x D25.
    And I want to define it as L = 100 , H=L/2 , D=H/2
    kevin_o_toole_1kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
    @turan_aydin
    If the variables H and D only depend on length, they do not need to be configured.
    Here's an example accomplishing what I think you're saying:
    https://cad.onshape.com/documents/d8bfc777e7f46fc2f1a4be67/w/da2603b8d1603199cf48b5cd/e/de8b269801e1f03af5b61a39
    But what if you wan't to chance the way how they depend on each other according to configuration?
    In that case you would configure Height and Width variables and enter #Length/2 etc, into the table cells?
    Nice example in the demo video whereby a shaft diameter is set with a logic driven expression.  So if shaft length over a certain value make it thicker.  Even has a chap with a proper accent narrating it o:)
    O.S.
    bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
    @3dcad
    Something like this?  and as @owen_sparks points out, the video shows a nice conditional formula.
    www.accuratepattern.com
    @bruce_williams
    Probably so, for some reason OP had difficulties on performing that..
    @bruce_williams Thanks,. exactly !!!
