problem putting a hole into a thickened surface. Hole goes through part but not surface
Hello, a hole will not cut through the surface, only through the part itsself. The part is created as a thickened extruded surface (I was practicing some in-contect design). The same is true if I do a normal remove extrude. Why is that and how can I get the hole to cut through the surface ? Thanks for your help.
Link to model:
https://cad.onshape.com/documents/7c3e9a33127d9a8d93044ef2/w/c2ff4d9ed57380299c487e8b/e/d95d97463f1f480b57533fd6
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    An extrude remove is a solid only feature. Best thing to do would be to just hide the surface. If you really need a hole in the surface you will have to use the Split command followed by Delete Face. Info on these commands can be found in the help.
  • gunther_schwarz444gunther_schwarz444 Member Posts: 4
    Phantastic! The split command did it! Thanks a lot for your answer.
