problem putting a hole into a thickened surface. Hole goes through part but not surface
gunther_schwarz444
Member Posts: 4 ✭
Hello, a hole will not cut through the surface, only through the part itsself. The part is created as a thickened extruded surface (I was practicing some in-contect design). The same is true if I do a normal remove extrude. Why is that and how can I get the hole to cut through the surface ? Thanks for your help.
Link to model:
https://cad.onshape.com/documents/7c3e9a33127d9a8d93044ef2/w/c2ff4d9ed57380299c487e8b/e/d95d97463f1f480b57533fd6
Link to model:
NeilCooke
Moderator, Onshape Employees Posts: 5,992
An extrude remove is a solid only feature. Best thing to do would be to just hide the surface. If you really need a hole in the surface you will have to use the Split command followed by Delete Face. Info on these commands can be found in the help.
Senior Director, Technical Services, EMEA1
