Can someone help a newbie with the shell command please?
Hi everyone,
i am new to onshape. I am trying to design a hull of a model sailing boat (for 3d printing) on the basis of an imported STL file. I have created the hull as a solid like this:
I read on the forums that a common cause for shells to fail is intersecting geometries. I tried the method of splitting the part and moving the split to see where it is failing, but i can't see anything wrong.
My model is here:
https://cad.onshape.com/documents/3131c85f0fd3d7809ac8f727/w/322214c9ebfb3b5e800f398d/e/2e77eba269d0b582758770fe
Any help would be greatly appreciated.
Erik
- Trace 3d splines over the STL (the STL is only half of the hull)
- Create a surface by lofting over the 3d splines
- Mirror the hull surface.
- Create the deck and the stern.
- Create an enclosure.
My model is here:
Erik
kuifje_tintin Member Posts: 7 ✭
Hi Neil and Mahir,
thanks for the tips! This is a good exercise!
So i tried both suggestions:- Here I "cut" some tiny bits of the stern and the keel (didn't need to remove the bow) and now it seems to work so that's good. hmm I have to say i'm not really comfortable with such unpredictable behaviour but i don't have any 3D Cad experience. Especially since i don't see anything strange. Also i am now left with pieces of hull that are thicker than necessary adding extra weight to the hull. But it's not too bad.
- Here I tried to model half the hull, but i don't manage to enclose the half hull. Could you try to see what it is i'm doing wrong here?
https://cad.onshape.com/documents/4587481b3c3175ea0e060a57/w/d2883eaca5e69534240b26db/e/300dc1ee301f3d43ef5dc882
thanks for helping out, i'll try both ways and let you know!
Come to think of it, if the sharp curve at the bow is the problem, i can also soften that a bit, see if it helps. But cutting ofs a small piece of the bow and make that solid is definitely also an option. I'll have a go at it!
Regards,
Erik
